LC200 US with Diesel...consequences?
Hello All!!!
First and foremost, thank you for all the information that I had the pleasure to read over here !!! What a great community !!!
Found a possible-buy LC200 2008 with ~50K miles. While checking the Toyota history, found this:
CUSTOMER REQUESTS STARTING SYSTE M CHECK --IT KEEPS CRANKING-BUT DOES NOT START- IT WAS TOWED IN ~|~IT HAD DIESEL INSTEAD OF GAS --TECH REMOVE GAS TANK AND CLEAN ALL INSIDE ~|~ALSO FLUSH ALL FUEL LINES, PE RFORM FUEL INJECTOR SERVICE AND ALSO CLEAN THROTTLE BODY PERFORM ALSO TOP ENGINE AND CARB CLEAN --REPLACE NEW TOYOTA BATTERY
:bang::bang::crybaby::crybaby:
The question is: What are the consequences of this mistake? What was done is enough to grant no more issues related to this "diesel" later on?
Thanks a lot !!!
MWLC
Putting diesel in a gas engine really isn't a big deal longevity wise. However if you put gas in a diesel that is bad news.
They just need to flush the fuel system, change the plugs, and probably change the oil.
I have put diesel in gas engines before (unmarked tanks on a farm were reversed when the tanks were refueled by tankers) and had no long term side effects..
Thanks a lot!!!
Any other with more feedback?
Cheers.
No real experience personally. But Diesel cannot really do any harm - assuming that the fuel system was thoroughly cleaned out. I doubt that it would have combusted at all in the engine. If it did, then it is possible that a bunch of oil/diesel got int the exhaust/cats, etc. But that likely burned out when all was cleaned up.
Any way to call the dealer/tech who did the work? Probably not too hard to remember that repair as it is unusual!
BTW, I had a MB diesel. I always feared the opposite - someone putting gas in the tank. Now that is a very bad thing.
Good luck.
Good luck.
I saw the engine on a 250K tractor get destroyed when it was filled with gasoline!! Bent rods galore!!
I have found that a gas engine will run on diesel, but it will not start on diesel. It is also going to smoke like crazy. This was on a gas-powered F-250. The more modern electronics in the LC might not work with it.
SO, in a worst case scenario, you can drive your gasoline powered engine on diesel, just don't turn it off until you get where you need to go.
I had a 1983 MB 300SDL when I was in college. One morning after a long night I stopped at a country store to get some fuel. After putting about 8 gallons in the guy at the pump said "son, I could be wrong but isnt that a diesel?". I topped and it off with some #2 and drove it like I stole it all the way back to Chapel Hill. Car ran fine and I never had a problem. That car was awesome.
I's swap out the fuel filter just for peace of mind.
