Johan,
You can try Neil at RooDogs in Australia. He is very helpful and may be able to source you a 60A alternator in 24V. There is a limit to the output of these alternators given the small size, but the two belt pulley is a good idea as the output goes up. These smaller case alternators will max out about 80 - 100A (@12V) due to diode sizing and cooling limitations.
Running things like LED driving/off-road lights instead of halogen (1/3 the current load for the same raw lumens), all other lighting for camp use or interior can be switched to LED as well.
As others have stated, try to keep your weight down (there's no real need for more than one extra battery - and it doesn't need to be that big), and try to run as much native 24V stuff and you should be good. 60A @ 24V is a good lot of current, considering that these diesels don't have any real draw when running (except for a few mA for the fuel shut off solenoid). Lots of people make the mistake of thinking in terms of what a petrol powered vehicle needs - computers, ignition systems, sensors etc. that all use a fair bit of current. The PZJ has virtually none of that stuff, so what the alternator puts out is not going to need to be high as what one would need when you run that thin, stinky, highly flammable fuel alternative.
~John
