- Thread starter
- #21
HAPPY FATHER'S DAY!
(to all who are; I'm not)
So a dear friend of mine who probably has 50 years experience fixing his own cars, came for help yesterday. As predicted, the snap ring (C-clip) was found loose and unbroken in the dust cap, with only a little grease left in the cap. The axle had retracted inward (first photo). By pushing (and pulling) by hand, the axle could not be pulled out enough to see the clip groove; we didn't have a proper puller available. The splines? near the end of the axle are stripped (second photo).
Wheel doesn’t turn freely (so the drive flange doesn’t appear stripped) but it is frozen (couldn't remove the drive flange with hand tools), and since the inside oils seal is also damaged as well, we decided to do a temporary fix just to make it driveable to a garage. See my friend's work in the third photo: with a piece of heavy gauge 1" PVC tubing, he made a spacer ring, which is held in place with a couple of washers on a bolt threaded into the axle center hole. This arrangement seems to have pulled the axle out enough as well, although we have no access to put the clip back on.
My friend thought that this failure probably had happened because it had not been properly maintained. The original owner, who gets credit for doing 248k miles on it, though, had it repaired only after something failed. And I was counting on an oil change service with 23-point inspection and wheel-balancing to their job; but not all of their locations seem to have the same high standard of care. The rust that you see in earlier photo is not so much from driving, but from this vehicle sitting idle outside for many weeks, after the shaft getting exposed. I treated exposed parts with SeaFoam Deep Creep ™ thoroughly before I put the things back together, as described above.
The obvious question was will there be too much heat to weaken the PVC ring? We did a test drive of 10 miles roundtrip with speeds up to 50 mph, and the axle end was cool to touch (even by a baby) midway during the trip and at the end. And there was no noise either (which was also the case with Center Diff kept locked, even before yesterday's fix). So we believe that this is driveable to a garage about 20 miles away, which has to be arranged.
Thanks again to all who advised, and I will keep you posted on the outcome.
