Yes, I know about how locking the brakes increases stopping distances. Good luck locking the brakes on a properly functioning ABS system. I guess I need to spell things out for you........
LISTEN TO WHAT I AM SAYING.
If, right now, with your brakes hot (as in maximum fade effect, as in
not cool brake fluid, as in you've been riding them a while--does this cover all the bases for you?) you can still hit the brake pedal hard enough--as in a
panic stop--to necessitate the ABS system to kick in (all this I previously stated as "locking them up", but guess I should have spelled it out for you), upgrading your brakes will not net you much.
Let me repeat this all again, as I am sure your satisfaction and understanding will neccessitate:
"But like Gumby said, if you can lock up hot brakes now, upgrading won't get you much."
".....if you're driving down a long road into a valley, you've been hitting the brakes pretty hard, so obviously your brakes are hot, yet they still work great, upgrading won't net you much."
"Hmmmmm..... If you can lock them up, isn't that normally a panic stop is?"
Echo, echo, echo..........
