You state that as fact, on what basis?
I suppose that this statement might technically be true since the 100 series is undeniably younger than any 80- or 60 or 55 or 40, any of which I would argue will be proven to be more mechanically reliable than the electronic-dependant 100 in the long term. For that matter, the 80 pushes my personal limits of what should be electronic. For me, the coil suspension, solid axles and overbuilt design makes up for the electronic transmission and climate control- neither of which has been shown to be a problem, but still... the more complex a machine, the more likelyhood for failure.
The original question referenced cost of repairs. How would you rate the 100 in that category Shotts? (No digs here, just trying to help the poster and I have no experience with 100 series repair bills.)
In the end they're all Land Cruisers and worthy of consideration. The 100 is undeniably the flagship for luxury- to date.
-Spike
The reliability stuff has been well noted on MUD. Consumer Reports over the years showed the comparison as well as numerous other choices. The 100's had less required repairs both early in life and as they age. It's amazing how all the little and nagging failures the 80's have were eliminated in the 100 (as they should).
Overheating
Bad sunroofs
Poor power windows
AT shifting issues
Engine failures
A/C cut out
Poor brakes
Unless you are bulding an extreme wheeler there's no reason to put up with old technology unless you can't afford the new.
The 100 has a few issues though the frequency is much less than the 80's nagging ones.
Manfolds
Starter
This guy stated "DD then eventually a wheeler". That's why he was asked by me about that and if the 100 was in his sights.
By the way.....the "over built design" is even more impressive in the 100 compared to the 80 (as it should be). The FF axle answer doesn't hold water unless you're building a ShortBus, so don't try it. In every other way (frame, strength, engine, structure, brakes, creaks and cracks...frame caused) the 100 bombs the 80 for being over built.
It's up to this guy. If he wants a Rubicon Trail rig eventually then I change my tune. If he wants to run almost everything but that....why live with the old stuff when the new offfers so much more?
