Hi all,
I’ve owned my 2009 land cruiser 79 series V8 for 10 years now and never had a problem whatsoever. However just a few weeks ago I was driving and the engine check light came on. There was no change in power or anything obvious, so I kept using the car as normal.
But just a week ago I decided to plug in my OBD II scanner and it showed to have the following 2 error codes:
Having done so and cleared the error codes from the memory we decided to test drive the car a few kilometers. Everything was fine, but the next day when I started the car in the morning to go to work, the engine check light came on! Plugged in the OBD II scanner and the exact 2 errors again!!
Since the errors showed up with the speedo senor and brake switch borrowed from my mates 79, eliminates the possibility of either the Speedo senor or the brake switch being faulty. I have since followed up the connectors and wiring as just to make sure everthing is in working order, but still no luck with the engine check light going off!
I have no problem driving the vehicle as the Speedo function as normal and so do the brake lights, but I do plan on selling the car sometime in the near future and would like the engine check light being switched off! I would really appreciate feedback from anyone whose come across a similar issue or just some advise on how I can erase these errors.
Thanks
- P0500 – Vehicle Speed Sensor Malfunction
- P0504 – Brake Switch A/B correlation
Thanks
