KZJ78 Transfer case gears
Canada
I am in the midst of a not so good transfer case rebuild. 38mm split case off a 1995 kzj78. I am looking like i'll need the rear output shaft as well as gears. The needle bearings inside the gears have done a number. Does anyone have experience regearing this particular transfer case. Also what sort of overall cost it was?
Thanks
Thanks
Did you ever end up regearing your transfer case? I have a 1995 KZJ78 with a bad transfer case that I’m looking to rebuild or replace. I haven’t had any luck finding anyone that can rebuild and Marlin Crawler doesn’t do it any more. I may have to order from Megazip
We can certainly help. That particular Tcase can be reheated without issues. Post some pics of what you have and the issues you’ve encountered. We should have all the parts needed in stock.
Georg @ Valley Hybrids @ Cruiser Brothers
Shop 209-475-8808
Sales@valleyhybrids.com
Shop 209-475-8808
Thank you very much for the response. I have a leaking TC and we’ve found metal shavings.. enough that it looks like we should replace or rebuild. I’ll be in touch tomorrow. Thank you as well @OGBeno
