KZJ78 no airflow
Okinawa
My Prado stopped blowing any air from the AC or heater today on my way to work. Anyone have a good part number for the blower motor?
Thanks!
Before springing for a new blower motor check the blower resistor and the fuse. The resistor is located up in the passenger footwell behind the blower motor:
If neither of those are bad the blower motor part number is 87104-89110.
Great thinking on the dummy checks. Sadly the blower motor resistor and fuses looked good so I’ll be buying the blower motor. Just to be sure, the fuses I’m looking for are the A/C and Heater fuses next to the drivers right foot right?
Hello,
Check the fan control switch for electrical continuity.
If there is no continuity, try some contact cleaner and test again. If there is still no continuity, replace the switch.
In old age, the resistor gives up the ghost. So does the control switch.
Juan
Hello,
Juan
Juan,
Good thinking, I’ll check there too. I used my heater today for the first time in a while and then it just quit.
I've had to replace my blower motor before too. It was a match with something north american, I forget now. Might have been a FJ60 (or 4runner as above).
thanks for the thread. My first two fan positions quit working and I pulled the resister and found a broken connection on one of the coils.
Wanted to post up as a thank you to the above info! My KZJ78 Prado had two issues related to the AC. One of which was the AC resistor. The symptoms were only off or max fan speeds, no in-between speeds. A quick replacement of this part remedied this.
The other issue was the fan sometimes would not run at all, and when it did run, it made a pretty loud howling sound and constant clicking noise as well.
The OEM replacement fans from overseas were pretty expensive ($250 or so with shipping). I did end up going with another user's recommendation above of trying a early 4Runner AC blower and this worked perfectly. I was able to pick one up from my local Autozone for $41 and it was a direct fit.
The exact part number of the blower I got was "PM3715" made by Continental. https://www.autozone.com/cooling-he...792994_0_0?searchText=PM3715&redirectUrl=true
