KZJ78 - New window/lock master switch - Let the smoke out...
J78
SoFla
Had an issue with my driver's side window and assumed it was the switch. Turned out to be the regulator/gears in the door jamming. Old switch works fine, but is a little worse for the wear, so figured while everything was apart, I'd replace the switch. A new switch from Megazip and others was in the $300+ range. Found what appears to be a new/genuine Toyota switch on E-Bay for $80. Switch arrived today and looked the same, but the plug would not connect without shaving some small plastic "humps" off the connector. Plugged in and the window switches did not work. Tried the power door locks and POOF! Smoke came pouring out. Turned off the key, removed the switch, replaced with old and everything works as it should. Did I get a counterfeit, bad unit or what? Anyone have any luck with the "expensive" switch? I don't mind spending the $$$, but would rather not. The only time I roll down the windows in this FL heat is to explain to folks why I'm on the "wrong" side...
Hello,
That is not a 70 Series part.
A proper 70 Series switch is within that price range. Replacing it is plug and play.
Juan
  • Like
Reactions: J78
Hello,
Juan
That's the Part # from MegaZip and confirmed with ToyoDIY:
84820-22310
Master Switch Assy, Power Window Regulator
[05.1993 - 01.1995] KZJ78..EX,SX
Japanese Warehouse
5...7 business days
US $301.34
Japan01/1990-07/2004TOYOTA LAND CRUISERFJ75,LJ7*,HZJ7*,PZJ7*,KZJ7*84-01: SWITCH & RELAY & COMPUTER
Master Switch Assy, Power Wdo Regulator 84820-22310 fits for​
Models
Hello,
The parts catalog has a list that mentions Camry and Starlet. At the end of the list, it says Land Cruiser, specifically, JDM Land Cruiser.
By the way, by Price Range I meant around US$ 300.00. At US$ 80.00, the one you bought is likely counterfeit.
Since the part you bought blew up, it is worth checking circuit voltage as well.
It is worth trying a master switch from an 80 Series Land Cruiser.
Juan
  • Like
Reactions: J78
Hello,
Juan
All parts catalogs indicate KZJxx and Prado.
Voltage checks out fine. I was initially troubleshooting the original switch, only to realize it wasn't the switch. Original switch works fine, just thought I would update it for aesthetics.
I'll research 80-series switches.
Thx.
Part # from the 80 series cross-references to the same (toasted) part # as I have, and it looks identical:
Models include: Landcruiser all 80 Series FJ80 FZJ80 HZJ80 HDJ80
All Landcruiser VDJ76 and VDJ79 Dual cab only
4Runner VZN130 from 8/1990 to 10/1995
Surf (imported only) KZN130 LN130 VZN130 YN130 from 4/1989 to 7/1993
Part numbers for reference: 84820-35020 84820-22310 84820-22330 84820-32140
That’s a total fake part. Junk.
Hello,
It is settled then.
Make sure you get an original part from a serious supplier, or from the local dealer. Now you know about the price range.
Juan
