I'm not sure I'm confident enough to run without both sway bars, certainly not the front. Hopefully by at least extending them I'll have better flex than without doing so.
It seem to me like if you're running 100mm lift with stock brake lines I should be fine. But I noticed others said they needed to so I guess I will just have to see after the lift goes on.
The only time I've noticed the brake lines looking tight is when I've lifted the truck off the ground by the frame and let the entire axle droop. But when the truck is on the ground and articulating either way, the lines seem fine. So maybe it would only be a problem if I get air in the truck?
