The hipinion front pinion offset is std even with 4.88 so re-gearing is not an issue in this instance.
Thanks for your input. Good to hear that the front 4.88 carriers can take aftermarket gears.
When I swapped my 4.3 pumpkins for 4.88 the plan was to use the ring and pinion in my rear e locker... but I discovered the issue with the off set.
The LJ78 came out with front and rear e lockers as an option. I have only seen a rear in a Jap import here in NZ.
The KZJ78 also had the same options, but again only seen a rear setup. Mine was removed from a KZJ78 roll over....So I got the controller and harness from rear chassis to diff.
The axle housing was bent so no good to me.
Lucky for me the rest of the harness was already in my truck. Just had to run the trigger wires to controller and put in a switch.
I was given a speedo from an LJ which had the elocker indication light in it.
So I took it out and grafted it into my speedo / rev counter.
So Tassie KZJ78 you are good to go as long as the ratios match.
