- Thread starter
- #121
I’ll have to look I believe I removed those just need to locate and see how many clips I have.Looking for the splash guard in the driver side wheel well and any clips you can salvage. Shipped to 20007
The one on the shelf sold last night but have one off the 99 which should be the same. I’ll grad it tomorrow when I’m at the shop and send pictures. Let’s do $130 shipped.Sweet what's the code on the throttle body?
I just want to match them up. And shipping is to 08701
Yep that’s a no brainer. New clips are probably best also.don’t worry about it, a new one with clips is only like $15 from the dealer
Hello, do you have any crossbar tension knobs available from any of the roof racks you have on hand?
View attachment 2338005View attachment 2338006
Looking for a 100 series tool kit with spare tire key specifically![]()
GoneIs the passenger front. Corner lens avail and the Hvac controls with trim bezel?
Was planning on selling all the visor stuff together but $40 shipped on one. Add $40 for middle row lightsHello
I would like prices on the following items, please:
Both front headrests. Tan.
The 2nd smaller sunvisor behind the main sunvisor, driver's side.
The three rear facing ac vents in the 3rd row. They are screwed in, but they pop out of the headrest easily
Center interior light assembly, center of headliner, middle row.
The top trim piece on the rear hatch.
Shipped to 37938, please.
Costs? Thanks.
do you have the cable guide casing and drive cables (both sides)? they are on the sunroof (see image). they need to be able to slide in and out if your sunroof works they slide.
It sure about shipping the whole piece is over sized pulling parts Only saves in shipping $40 plus shipping while thing is $80 + in shipping I’d guessdo you have the cable guide casing and drive cables (both sides)? they are on the sunroof (see image). they need to be able to slide in and out if your sunroof works they slide.
Should have that $85 shippedHello looking for the rear cross member wiring harness do you have that? its located behind the rear cross member, goes from one side of the truck to the other had 4 plugs or so.
Thanks!
