Just received my 12" digital.calipers.I have been waiting for, so.start the knuckle centering. I have the FSM in front of me, I've read a large number of threads on the matter. Seemed fairly simple to me, I thought there was no way I.was going to be making this post.
Left A:167.58mm B:165.1mm C:2.48mm
Right A:167.59mm B:165.2mm C:2.39mm
Total shim thickness is.within .2mm of the shims I removed. Though I saved and marked the old shims they are going back on a different axle.housing, so I thought it would.be prudent to measure everything.
All above seems fine, however the two scribe lines on the tool (one from the housing the other from the spindle) are right on top of each other. There is no gap to measure to find top and bottom shim thickness.
New spindle bushings, and I did not flip the tool orientation, threaded end is on the bottom. The axle housing is a cut and turned SOA housing from Proffit's, the knuckles from an 82 mini truck
