- Year
- 1997
- Vehicle Model
- 80 Series
- Location
- Knoxville, Tennessee United States
- Mileage
- 277000
- Color
- Green
1997 40th Anniversary Edition Land Cruier 3x Locked.
15,000 OBO.
Selling because we bought a house and it needs a lot of work. Looking to sell quickly.
PHOTOS:
40th Landcruiser For Sale
It was salvaged in '15 as a total loss with no reasoning but immediately reissued a salvaged title and a rebuilt title in 2015 with a new owner. I bought it in March of 2016 and have owned it since.
- Parasitic Draw (being worked on)
- Axle seals leaking (being worked on)
- PS Reservoir leaking (will be fixed)
- Clear Coat on hood
- Couple dings on the body paneling
- Seats are a little cracked
- Little rust spot on the back hatch left glass frame
- Had to do a little Trail Fix on the rear heat so it was bypassed with a hose kit from Auto Zone.
- New OEM drive shafts New 3rd Members in both diff's with new bearings and races.
- All Lockers Engage as they should
- New Valve Cover Gasket
- Distributor O-Ring
- Regeared Yukon 4:88's
- Power Stop Drilled Slotter Rotors
- 5x Toyo 385/70R16 MT's
- 5x SCS F5 Black Wheels
- Rebuilt the Knuckles (multiple times over the years)
- Metal Tech Adjustable Upper and Lower Links
- Adjustable Track Bar
- Adjustable Panhard
- Delta Panhard Bracket
- Delta 6 Radius Arms
- Ironman Foam Cell Pro 5" shocks
- Dobinson Poly 30mm Coil Spacers
- Dobinson Variable Tapered Heavy Coils
- Slee Short Bus bumper
- Warn 10k Winch (Steel Cable)
- Custom-made rear Swaybar links (dropped)
- Land Tank Blue Core Fan Clutch
- OEM Door Molding Set (New)
- Wits End Useless Cubby Insert
- Kenwood Aftermarket Head Unit and After Market Speakers
- Ultra Gauge ODB2 Scanner Mounted
- Center Diff 7-Pin Mod (Allows Center Diff Lock in 4-Hi)
- TJM Roof Rack
- Custom Build (Strong as hell) Dual Swing High Clearance Rear Bumper
- Custom Build Tubular High Clearance Sliders (Welded on)
- Custom Cut Rockers for even Higher Clearance
Things I Own I haven't installed yet
- ARB Dual Compressor
- Slee Dual Battery Box with Compressor Mount
- Delta Rear Bump Stop Extensions
- OEM Rear Bump Stops
- I have an entire set of everything required for a front knuckle rebuild again...
- Synthetic Rope
- Factor55 Fairlead for Synthetic Rope
- Factor55 UltraHook
- Safari Snorkel New In Box
- OEM Oil Pump Gasket
- OEM Large Capacity Oil Filters and crush rings
- 3x Fusible Links
