So earlier this week I had a 3 inch lift installed on my 98 4runner dd. The lift looks great and raises the truck to the perfect height, for now, but since the lift has been in, I'm hearing a knock coming from the driveshaft or the rear diff.
Everything underneath is solid. I've been under the truck many times since the knock started and nothing is rattling around or loose. The u joints are fine and the angle of the driveshaft isn't too bad. The knock is only there putting around town (stop and go driving). When I'm cruising on the highway the knock is gone. I've jacked up the rear end of the truck and put it in gear to see if i could find out exactly where the sound was coming from but it didn't knock at all. I've also had all the oil in the rear end changed but that didn't help either.
Has anyone else had a similar problem or any advice would help?
