Key Switch Replacement My 1987 60 has been down for awhile. No cranking, battery drain, lights and buzzers good. I replaced the battery and the starter and through brilliant deductive reasoning have concluded the problem is on the steering column. The key needing to be jiggled to start in the past kind of pointed me in this direction. So, I am thinking key switch replacement. After 25 years of work and maybe too much graphite the switch contacts could be worn.
I am considering by-passing the key switch in favor of a "starter button" like on my 1942 Chevrolet. Holding the security issues aside, is it feasible to by pass the key switch on the column in favor of a button or are there too many other circuits in the key switch that must be closed for propper functioning? I would like to avoid creating other problems. Replacing the key switch is perhaps a better solution I just do not know about availability.
Thanks in advance for any comments or suggestions.
