as mentioned above the factory ECU will adjust over time. You could get an error code about too much air coming through if you go too extreme, but it's a case of the ECU not being used to it.
Most of the people here (edit: here in OZ) doing the performance exhausts and air intakes (be it cold/cool air intake or forced induction) will get a piggyback ECU. There's several around.
A common one here is the Xede
http://xede.com.au/ which has had very good feedback and recommendations but it depends how "wild" you go as you may then need to even replace the factory ECU with a Motec or similar.
When i got my LC V8 dyntotuned a few years ago (i posted on here about it) it came in at a paltry 82kW from memory (might have been less) and they said it was the Safari Snorkel that was the bottleneck. This was done before i did my exhaust mod and before i started playing with my Aussie factory airbox. The full airbox mod is over on lcool.org here
LCOOL.org :: Log in
All i did was remove the "spinner" or turbine, which doesnt spin.
As i havent been working for quite a while, my mods have come to a halt but i can say that the K&N filter (see my sig below for pics) did not put any residue on the MAF sensor. But it's a different model filter to yours. (see pics in sig)
However, i have switched back to the factory filter for now. You can see the size of the two in the pics.
I've been researching this for ages so i hope that helps a bit!
EDIT: this one will fit the non-VVTI V8s if you want to spend the money:
http://www.urdusa.com/Intakes-Cold-...ra-V8-w/Power-Box-&-MR-Tech/product_info.html
EDIT2: these are my performance bookmarks on Delicious (there are some PC specific ones so ignore those)
http://www.delicious.com/search?p=performance&chk=&context=userposts|moooooooo&fr=del_icio_us&lc=1
cheers
peter
