June 20th Boulder Bash rock crawl
10 N Main St. Troy NH
Website
www.drcustomwerx.com
Contestants Wanted
Looking for Event sponsors and vendors
Cheshire Fair Grounds Boulder Bash
Rock Crawl Rules
Safety Guidelines
Cheshire Fair Ground's primary interest is to enhance safety for spectators and participants as well as promote rock crawling as a motor sport. CFG makes no representations, expressions, or implies that compliance with the rules and regulations will guarantee against injury, damage, or even death to spectators, participants, and vendors. These rules and regulations constitute the minimum acceptable standards for competition and are intended as a guide for the conduct of the sport. The primary responsibility for safe condition and operation of rock crawling competition rests on the vehicle owner, driver, and spotter. Everyone associated with the sport of rock crawling must share the total responsibility for the competition. Rock crawling is an inherently dangerous sport. Each competitor assumes that risk when he/she participates in the event. Think safety first.
Cheshire Fair Grounds reserves the right to modify the rules and regulations for safety, environmental, and any other valid reasons at any time during the event.
Liability and indemnity waiver
CFG reserves the right to require all individuals competing in the event to sign a Liability and indemnity waiver prior to being admitted into any area of the competition.
Each participant of the event acknowledges the following while competing:
1) That he/she will at all times while riding in the vehicle will wear his/her approved seatbelt and DOT approved helmet.
2)That the owner/driver certifies that he/she has inspected their vehicle and certifies it to be in safe good mechanical condition
3)That he/she has informed him/herself and spotter to all rules and safety regulations set in place by CFG and has attended the drivers meeting.
4)That the driver or any other person participating in the event may at anytime bypass any obstacle or area they feel uncomfortable or unsafe driving through.
5)That driver and spotter is at least 18 years of age.
6) That driver/spotter must attend drivers meeting prior to event
7) That driver/spotter must wear suitable footwear. No open toed shoes.
8 ) That spotter is not allowed to touch vehicle while wheels are in motion.
9) That all fluid leaks will earn you a time out until the problem is resolved. You will not be able to continue until then.
10)Spotters will not be allowed to wrap rope or straps around any portion of his/her body during the event.
Modified Stock Class
Vehicle requirements
Modified stock class is intended for well-built trail vehicle modified using readily available aftermarket parts. The intent of this class is to stay within factory designs to showcase the ability of stock type trail rigs. Any rules or restrictions needed to maintain the spirit of this class will be implemented.
All axles must be mechanically differentiated. No hydrostatic drives.
No Rear steering axles
Both differentials must use some form of 100% locking device.
No portal axles will be allowed unless stock from factory.
No Coil-Over shocks are allowed.
Body must be full bodied OEM factory recognizable trail rigs. No tube body built off OEM frame. Some trimming of body is allowed such as fenders and corner panels. There is to be no trimming of hood, rockers, cowl, or firewall. No expanded mesh, lexan, or plexi-glass cut outs will be allowed on flooring or firewall.
Frame must be OEM type. No tube or partial tube frames are allowed.
Power Steering must be stock configuration. Hydraulic assist is allowed. Full hydraulic steering is not allowed.
Suspensions must be stock configuration design. Example: leaf from factory. Leaf for competition/ IFS or ,3 or 4 link from factory. IFS or, 3 or 4 link for competition. Stretching of wheel base is allowed by up to 5 inches.
Tire Size is 38” or smaller based on manufactures sidewall stamping. All DOT approved tires will be allowed. No Red Label BFG crawlers or agricultural/tractor tires will be allowed in this class.
Full Roll Cage is required. OEM bars are approved with built on front hoop.
Battery Tie downs (No bungee cords or ratchet type tie downs)
Functional seat belts
Fire Extinguisher
Front and Rear points of attachment
Operational Winch
Winch weight
Coolant over flow canister
UNLIMITED CLASS
The Unlimited class is intend for the most aggressive vehicles in the 4WD community today. Anything goes in the class. You can run whatever size tire you like because your probably too over built to run in the Modified Stock class. The only restriction for this class is that your vehicle must meet all the safety requirements.
Full roll cage or full body/cab
Full locking Differentials
Winch and winch weight
Battery tie down (No bungee cords or ratchet type tie downs)
Seat belts
Front and rear points of attachment
Coolant overflow canister
Fire Extinguisher
Mufflers are required
So you putting this on by yourself?
Make sure you post this over on NEOW.
Yeah. it's a lot of work and i could probably use a few hands if your not busy the day before and the day after.
I guess i'll have to Sign up for an account over there. haha i don't know what i've been waiting on. Just on so many boards now it's tough to keep up.
No offense but this looks like some lame ass s***. Kind of like monster trucks jumping over salvaged cars before heading to the crusher.
No offense taken tank. over the past fifteen years a new sport called rock crawling has taken off for people who don't get enough excitement out of class six roads. i wouldn't expect a land cruiser guy like yourself to understand or embrace rock crawling.
No offense but this looks like some lame ass ****. Kind of like monster trucks jumping over salvaged cars before heading to the crusher.
I think monster trucks jumping over salvaged cars is cool :frown:
This should be a good event, that DWE rock crawl draws in thousands of people every summer and is a really fun time. Even if you're not into rock crawling it's always a good time to meet other off road junkies and see what kind of creations they have come up with :)
well i was going to enter the 80 but by the looks of it it might be a little to easy for my rig:D so maybe ill just come and watch:cool:
looks like that is shaping up to be a good event hope i have the time free to get up there
It's today!!
Best caddy ride I've ever had; Josh was driving, Jay Ghelli was riding shotgun, and I was in the rear seat
Turning around after our practice run
Caddy hitting the ramp
Caddy about to leave the ramp
Caddy in flight
The caddy landing
