- Joined
- Apr 17, 2009
- Threads
- 17
- Messages
- 2,669
- Thread starter
- #481
On day one I blew out the slave cylinder on the descent down to the creek trail. Not sure exactly what happened, but, when it gave, it left the clutch fully disengaged. I was able to loosen up the rod adjustment nut enough to let it retract and engage the clutch. Then it was just a matter of turning off the truck to change from forward to reverse and starting it in gear. We sent the girls with the rest of the crew to finish the creek trail, and Ginny and I limped the truck back to camp without a clutch. That was fun.
Back at camp I was fortunate to find the only slave cylinder within a 500 mile radius in Knoxville (Jrob had given me Roger's number on the way out, but luckily we didn't have to bother him). We hit the road, and about 2 hours later she was rolling again.
Day two found us on Little School Bus (trail 38) where the picture above was taken. At some point my filler neck hose got punctured, and we leaked gas on every incline (looking back on it, this was probably caused by one of the hundred or so rocks/small boulders the girls had collected in the back seat). We tried to patch it, but didn't have much luck. I'll have to source a new hose before crawl.
The truck did well. The front end flexes better than I thought it would, but I'm not sure the rear is dialed in just yet. The springs are the same front and rear, but the rear just doesn't flex like the front does. I'm pretty sure this is due to the rear shocks. I'm thinking I should cut the rear fender wells, run shock towers up through them, and install some longer travel shocks in a 100% vertical position. This will be on the winter project list.
Steering worked ok...much better than the last update. My new belt whines under load, so it will be changed out soon.
Here are a couple more pics from Little School Bus:
