MRT Motorsports
MRTMotorsports.net
I am working on a ton of new deals for you guys and will be offering certain products direct to save you all even more money. This is the first group buy under the new structure and we look forward to many more.
JT Brooks Tire Delfators - Made in USA
Any serious offroader knows that sooner or later you will have to air down your tires. Airing down tires individually with a screwdriver is a painstaking process. JT Brooks automatic tire deflators make this process as simple as screwing on a valve stem cap!
J.T. Brooks prides itself on the fact that these tire deflators are completely designed, manufactured, and assembled in the U.S.A.
The idea for J.T. Brooks Automatic Tire Deflators started back in 1983, when two friends, Jon and Brian, ventured up to Lake Champlain in Vermont to meet up with family and friends for a weekend of ice fishing. On the long journey from Boston, MA, Jon mentioned that he needed an idea for his manufacturing engineering senior design project. Almost immediately, Brian mentioned the idea of a mechanism to automatically deflate your tires to a set PSI. Brian, who was from Cape Cod, would go to the beaches regularly and deflate his tires to improve his vehicle’s traction on the sand. He felt that the current deflation process of using a tire gauge and sharp object was long and tedious. Each tire had to be deflated individually and the tire pressure would have to be checked with the tire gauge over and over until the recommended PSI was reached. If you deflated your tire too far, it was a hassle to air it back up, only to deflate it again. They thought, “There must be a better way to do this!” After a year of research and tests, J.T. Brooks Automatic Tire Deflators was launched in 1984.
J.T. Brooks focuses on making a high quality product that conveniently and accurately meets the customer’s off-roading needs. We have expanded our product offerings to better meet everyone’s off-roading needs. Our keychain tire deflators allow users to measure the instantaneous PSI in his/her tire by placing a tire gauge over the threaded end, while the tire is deflating. Our automatic tire deflators, which have been available since 1984, can be calibrated to a desired PSI. This allows the user to simply screw them on and attend to other tasks before off-roading, as the automatic tire deflators quickly and accurately deflate each tire, while stopping deflation at the calibrated PSI. Our automatic tire deflators pro eliminates the need to calibrate each automatic tire deflator. Simply dial in your desired PSI, using our precision laser engraved PSI scale, and go! The automatic tire deflators pro allow for easy change in desired PSI, while on the move.
JT Brooks Tire Delfators GROUP BUY
2 Options to Choose From
Option 1 - Automatic Tire Deflators
Set of 4
$68 Delivered to lower 48 states
No one likes wasting time squatting down and running from tire to tire trying to set each tire to the correct PSI for maximum off-road traction. If you frequently air down for off-road adventures, then J.T. Brooks Automatic Tire Deflators are exactly what you need. Once a set of J.T. Brooks Automatic Tire Deflators is calibrated to a desired PSI, they are ready to use time and time again. These tire deflators automatically and accurately deflate tires to a set PSI. Simply calibrate each automatic tire deflator, by following the included instruction card, and lock them in place with the lock nut, screw them onto each tire’s valve stem, and let them do the work. The deflators automatically shut off when the set PSI is reached. This saves the user much time and frustration. By screwing one deflator on to each tire, all tires can be deflated simultaneously. This allows the user to complete other tasks while all tires are deflating. The automatic feature of these tire deflators eliminates the need to manually deflate your tires, so you spend less time setting your tire pressure and more time off-road.
Option 2 - Automatic Tire Deflators PRO
Set of 4
$88 Delivered to lower 48 states
No one likes wasting time squatting down and running from tire to tire trying to set each tire to the correct PSI for maximum off-road traction. If you frequently air down to different pressures and want to eliminate the calibration process,*then*J.T. Brooks Automatic Tire Deflators Pro are exactly what you need.*We have eliminated the need to calibrate each automatic tire deflator using a tire that has been deflated to the desired PSI. Simply use our precision laser engraved scale to dial in your desired PSI and go!* These deflators will automatically and accurately deflate your tires to a set PSI. Once you dial in your PSI, simply lock the tire deflators in place with the lock nut, screw them onto each tire’s valve stem, and let them do the work. The deflators will automatically shut off when the desired PSI is reached. By screwing one deflator on to each tire, all tires can be deflated simultaneously. This allows the user to complete other tasks while all tires are deflating.*The automatic feature of these valves eliminates the need to manually*deflate your*tires, so you spend less time setting your tire pressure and more time off-road.
Post up here if youd like to grab a set or two, we need 10 to make this buy happen
Set of 4
Set of 4
