Jerry Can Rack
Who makes racks for rear bumper mounted Jerry Cans? Was there ever a stock swing out rack made? I also need a solution for mounting my hi-lift but don't want to have to completely replace my rear bumper. Ideas? Thanks
If you don't use the rear for passengers, you can purchase a stock tube tire carrier (complete, hinges and latches) . Remove the tire mount so that you have a flat tube area to install a carrier for cans or a platform for a cooler. Install the hinges on the right side, (just like the left side) the tube will swing either way with the tire mount removed. Put the stock catch on the end and the frame clip on the rear sill, again just like the way it is on the left. ONly problem is passengers cannot get out the rear of the cruiser unless someone releases the right side latch. This works great if you have a dropdown tailgate.
