Can anyone explain to me or post a link where I can find the difference between the A440F and the Full Hydro non Electronically Controlled A442F found on the 1991 HDJ81's?
Cheers
Cheers
I haven't seen an A440F in a diesel JDM 80 series... yet.
In the gassers, yes, the A440F was there in the 80 series JDMs.
~John
John, I don't understand what you mean by cruise vs. non-cruise. Are you referring to the cruise control? If you are, how are the cruise controls tied into the transmission? I thought they only activated the accelerator.There are both hydraulic and electronic versions of the A442F. There are also cruise and non-cruise versions....
~John
I have an early production 1990 HDJ81 here (serial number is 000550) and it has an A442F in it.
Check that VIN tag, I am quite sure you will find an A442F in there and not an A440F.
edit 1: - I also have an HZJ73 that was one of the first produced in the 1993 model year - the VIN tag says it has an A440F in it, but it's actually an A442F electronic.
A collectible oddity perhaps?
edit 2: I only deal with VX 80 series vehicles, it is possible that lower spec units had the A440F (?)
~John
Christoman,
That is strange, I have rebuilt three of the A440Fs and every kit that I have purchased has been for the A440/A442 and comes with all the gaskets to build for either gas or diesel versions of either tranny.
If it is slipping in overdrive, it could be either a malfunctioning shift valve that is sticking or one of the seals from the valve body to the housing got hairlipped when installing or the sealling rings on the rear of the oil pump housing aren't sealing.
In any case, the tranny will need to be torn down to find out why and I wouldn't keep driving it or the clutches in the overdrive will be worn out quickly. The overdrive clutch is the weakest one in the entire tranny with only 3 clutches and steels to hold it.
Don
Hi longbow I have a 1990 80series with the full hydro A442f or really a a440f with a different belhousing it's in the transmission shop at the moment (6months now) the current status is has great reverse, no forward gears, on the lift the wheels are turning the right way but you can stop it with your hand . It has everyone scratching their heads including the two technicians who have 20+ years experience each. Valve body has been to a specialist toque converter has been rebuilt, case has been through at least six times. Any ideas???Christoman,
Don
Call Wholesale Automatic TransmissionsHi longbow I have a 1990 80series with the full hydro A442f or really a a440f with a different belhousing it's in the transmission shop at the moment (6months now) the current status is has great reverse, no forward gears, on the lift the wheels are turning the right way but you can stop it with your hand . It has everyone scratching their heads including the two technicians who have 20+ years experience each. Valve body has been to a specialist toque converter has been rebuilt, case has been through at least six times. Any ideas???
Kind regards
Michael
Drive flange?Hi longbow I have a 1990 80series with the full hydro A442f or really a a440f with a different belhousing it's in the transmission shop at the moment (6months now) the current status is has great reverse, no forward gears, on the lift the wheels are turning the right way but you can stop it with your hand . It has everyone scratching their heads including the two technicians who have 20+ years experience each. Valve body has been to a specialist toque converter has been rebuilt, case has been through at least six times. Any ideas???
Kind regards
Michael
