This topic has been brought up before, but there was no clear answer....
With a floor jack, is it safe to jack up the front of a 100 with the under-engine protection in place? (sheet metal stuff)
I do it all the time. There's even a raised ring there for your jack pad to go up against.
It's covered in the owners manual. Jacking points for the factory jack are at the front frame rails or the rear axle. That raised ring is part of the structure of the plate, I don't think it's intended as a jack point, doesn't mean it won't work but it's not one of the factory listed points.
While I would lift a corner with the factory jack, I'm not sure I would lift the whole front end. The factory jack may overload or the sheet metal could crease and things could change vary quickly (like the jack can come shooting out from under the vehicle seeking victims).
Please use jack stands under the frame rails whatever you do or you can die.
Sorry you got frustrated that Mud did not reply to your previous thread in a timely manner but it is a owners manual topic and a dangerous one at that.
Maybe this could be the definitive jacking thread and we could get some pictures on here. At least of the FSM or owners manual. I know some people may be wary of telling others how to jack up their vehicle, due to liability. But if properly disseminated, this information could save life and limb.
Good idea!
I'm also finding that 12 ton jack stands are very hard to position on the frame rails due to the large size of the "heads" on the stand.
False. I do it all the time and I cant think of a safer way. Plus those monsters are good to have around when crawling around underneath with no wheels/tires on the rig. I wouldn't do it with less, now that i have them.
Best thing to do is get sliders and/or steel bumpers front and back, and use a highlift. All but a necessity once you raise the vehicle with larger tires or a lift. Realizing this doesn't answer your question and is costly...
This is the internet folks, you have to be very careful when making an open invitation to post 'your jacking pics', this is a family site after all!
So are the control arms a bad place to jack in the front?
I'd like an answer to this as well. My jack doesn't have the height to raise the truck using the frame rails. I've been making stands out of iron weights to get the jack high enough.
You guys are making this way too hard. Just a floor jack in the center, that's all. Just put a jack in the middle where the round thing is and be done with it.
Personally, I would not recommend putting a side load on a jack stand by doing one side at a time. That's a good way to get a stand through your floor pan or into an AC line.
Edit: Open circles are scissor jack positions, squares are jack stands, although I tend to put my rear jack stands under the axles and my front stands on the frame at the front door hinge.
