- Joined
- May 26, 2013
- Threads
- 18
- Messages
- 89
- Location
- Thunder Bay, ON
- Website
- www.aarontatorphotography.com
Okay, this is a pretty stupid question, but raising a vehicle this size makes me a bit nervous. I've always just worked under it with the suspension set to high, but I need to pull the wheels off today... Also, I realize that I've opened myself up to all sorts of jokes with the subject line. Anyway, when raising the LX onto jack stands, does it make any difference what height the AHC is set to? I assume the suspension needs to travel the same distance either way, but jacking from high would save some effort? I mean, if there was an actual difference in suspension travel, we'd just be able to stick the truck on high, put jack stands underneath, set the vehicle to low, and the tires would come off the ground (which would be pretty great actually). Also, I only have the jack that came with the truck, I assume I'll need to lift one corner at a time, or can the scissor jack be used from the front centre jacking position? I assume it'd be too much weight. Is it safe to lift one corner to a jack stand at a time, or is it going to shift the vehicle around too much and make it unstable?
