Yeah, I just redid the clamps on the passengers side CV's. I Also used a marinade injector to squeeze a friggin bunch of CV joint grease in both boots. The inboard boot I peeled all the off and wiped as much of the REALLY runny grease as I could out. Didn't have any brake cleaner around. Then I clipped the sharp point off the injector, squeezed some joint grease in there and injected grease all into the CV joint itself. Well as much as I could with it all still put together and on the truck. On the outboard side I just pryed the boot back a little and squeezed in as much I could until the bad grease was bleeding out. I used ALOT of grease. I got a little less than 4oz into the outboard boot. I bet I got about 8 oz. into the joint and boot on the inboard side. Hopefully that isn't too much! At least I got all the clamps changed out so when I have a full day and plenty of brake cleaner, I can douche out the joint good.
If the squeak is still there by Friday, my day off, I will do the drivers side. The clunks and pops will wait until the squeaks go away.
