Scott- Naa the silver one is still more fun with the auto. Maybe with some seat extensions the white one would be fun for you to drive
Just put me a seat on the tool box.
me
DITO
may want to paint it a diff color ya wouldn`t want somebody in the heat of a fire to try to grab it by mistake
&fan da flames so to speak
Not sure on the tank size but it should hold 3 gallons with constant air supply only a switch away.
As ya'll know I have wire issues with the truck from the passenger seat back which is basicllyfuel pump, fuel gages, lights stuff I really need . Well I unplugged the wire harness under the passenger seat and pulled it all from the truck and layed it on the work bench and went to work on it . I unplugged each connector in the wire harness and sanded EACH contact to get the corrosion off the male plug in and the female plug , and rechecked continuity . All checked good this time. The wire harness has not cuts or breaks in it the whole time the trouble was the connector male/female contact. ALL the lights,fuel tank and gages work on the truck now !
(Paul I have now retired you and Johns "hot wire" fuel pump.)
Yea it might not seam like much to some folks but I had a grin from ear to ear knowing I did not have to butcher up the wiring harness on the truck![]()
[Great to hear Albert!
that is one of the things that keeps me turning wrenches
ya may want to pass a dab of dielectric grease in that plug to keep moisture out.
