When I pull the motor, I'll set them side by side and measure/take some pics. Very excited! I also ordered all the parts for the y-link steering conversion ala jcardona1. Extremely excited about keepin my 2.5", but if I gotta go 4", so be it
Thanks for the pictures, going to have to compare when I get the Slee 4" on.
It would be relatively easy to clearance the pan there since the oil pump and pick up is at the back. but loss in oil capacity would occur.
Can the engine be mounted higher? (I guess I'll find out soon enough)
You really couldn't clearance the pan enough because of the oil pump. And you can't really get the engine higher if you are using the stock air filter housing and location. I considered moving g the air intake to the driver side, but in the end felt the stock location might work better, as far as convenience, and it was maybe less work? One thing I will probably end up doing is putting a trans drop spacer, if it turns out the drive line angles are too out of whack. And some custom skids to go along as well.
So the only clearance issues with the oil pan on this swap is between the pan and the tie rod ?
Great update! Looks like you have gotten lots done. Looking forward to the weekend update!
