Background:
I bought a new oil pan and gasket, the old one was cracked. I changed it, but did not install the gasket correctly so its leaking.
Issue:
The flywheel cover overlaps with the back of the oil pan, clearly it is supposed to be removed first, then the pan & gasket changed, then reinstalled. The problem is my exhaust runs close against it, consequently I cannot install it (or remove it) with the oil pan up. What I did on the first install was to put it sorta on (you have to twist it as your remove it and it needs to rotate into space the oil pan occupies) and then try to install the oil pan. Clearly, this wasn't the best way of tackling the problem because I couldn't line up the back of the gasket exactly properly. Needless to say, the back of the gasket isn't lined up and now leaks.
Question:
I can't really remove the exhaust without taking it completely off, so I'd like to avoid doing that. Is there an easier way to do this that I'm missing? I have taken a number of photos so you can see what I am seeing.
More photos, and full size versions are up on my photo gallery: http://andrewloe.com/gallery/view/wheeling/fj60/oil-pan-issues/
Issue:
Question:
