The radiator is at least 8 years old. Possibly more. How long they last?----Looks like I'll be doing HCV, all coolant hoses, & PHH within next few weeks. Does PHH bypass mean 2nd row passengers don't get heat?
PHH bypass is when you replace the perfectly good metal tube with a hose. It doesn't change flow of heat to 2nd row.
The rear heater bypass cuts off flow to the rear heater.
I think the PHH bypass is not only a waste of time, but it puts stress on the relatively fragile HCV. The rear heater bypass is up to you. The 12mm hose going to the rear heaters is harder to install than the PHH, imo.
If I were you, I'd replace your fuel filter at the same time you do the PHH. Also, I'd unhook the line to the knock sensor first, and tuck it out of the way so you don't break off the knock sensor like many of us have done, while you do the PHH. Be sure to hook it back up when you are done.
Replacing the PHH is easy, imo. If possible, do it on a lift. Go in through the driver's side wheel well with the wheel removed. Remove the soft skirts, and just cut the PHH.
Then, go in through the top and cut the top hose, and undo the top bolt. Once this is done, push the rigid line back and forth, (from the top side) while simultaneously twisting. After about 15 minutes (which seems like forever, I know) the bottom tab will snap off. Then you can remove the rigid line. At this time, remove the half of the PHH from the block and tube side. Be sure to remove any corrosion from the tube and shoot some paint on it, while it's off. Then, just reinstall.
