rover67
I'd stick with mechanical...
Being in the Chevota business, I deal with this every minute of my life. I've been giving the same advice for 38 years now, and nothing has made that advice change to date.
(a) The only problem I have with electric fans is that normally the only ones with high enough cfm to cool your rig are too big and won't fit inside your engine compartment. Consequently guys run 2,000 to 3,000 cfm when they actually need 4,000 cfm.
(b) There is nothing I like, or ever will like about flex fans!!!!
(c) I like big bad-ass, chain saw massacre, engine driven air conditioning fan blades that have the torque of the engine behind them. You need a gosh darn hurricane to blow out your engine compartment oven, and nothing is going to do that better than an engine driven fan!!!!!
Now, new subject---DO NOT put any portion of a fan blade up inside a fan shroud. That's the number one problem I see every day. If you need, or run a fan shroud, make it end at the front edge of your fan blade!!!!!
