Check out Spressomon's build tread he relocated both top and bottom rear shock mounts for some custom Fox shocks.
Uh oh...now you've done it.
Yes, you are correct, there is no gain in travel with this mod. You gain some here but you lose it there. But what is changing is the percentage of up-travel vs down-travel. Let's just say there is 8" of travel in the front and 10" in the rear. The stock front suspension is roughly 50/50 (up/down). The stock rear suspension is maybe 40/60?
Now lift the suspension 2" all around without doing anything else and you have roughly 75/25% or 2" of down travel in the front and 60/40 (4" down) in the rear. By comparison, most rock buggies would be maybe 20/80. Desert racers might be 50/50. What is best for you? I don't know.
But for me, 60/40 in the rear seemed like it lifted a wheel more often. The front will for sure lift a wheel more often with just 2" of down travel. I'd like to gain more droop in the front while sacrificing some compression but it seems like the steering arms, cv's and ball joints are putting up a good fight. YMMV... just my 2 cents.
Carl, do you have a picture of your 100 showing the front suspension, one side fully drooped and the other side compressed?
My comment about the front extended length shocks and steering problems is because it appears if we go with too much (2") extra droop in the front, the steering goes rapidly into an extreme toe-in position. I'll start a new thread after some more testing.
