I'll guess the answer
There was about 1/16" side to side wiggle of these idler pulleys after I removed the belts so I removed the pulleys for inspection. I found the closest fitting drill bit and wrapped around it aluminum foil to shim it tight into the center of the bearing. If found no play there whatsoever and a smooth feeling rolling action as I spun the outer wheel on my newly constructed but temporary shaft. I made an executive decision and now since I am an expert at changing belts, it won't be a big deal to just let them go as long as they desire and not waste any money that isn't necessary.
By the way, the play in the wheel is from the rod that goes through the bearing being a little smaller. Not sure the tech specs on this but again, I'll leave it until I hear it start to rattle. I may go ahead and throw a replacement bearing in my tool box for the next trip down south.
