I used square weed eater string and windex. Started from the bottom center and worked my way around to the top corners, took bout two hours. Good-luck
Still own it? Any updates?
Irish's Feb 1978 Rustic Green FJ40:
Current Photo: (May 2016)
Completed list of everything I have done to the rig since I bought it:
Completed Mods:
Body/Exterior:
- Factory Rear Bumperettes
- HFS 8274 Bumper
- OEM Bumper gussets
- Front Bumper Side Frame Brackets
- Paint
- Toyota 621 "Rustic Green
- "Ford Performance White" for bezel and top
- Rebuilt Doors
- Weld on lower patch
- Door seals and window felts/wipers
- Rebuilt Hardtop
- Racer Hardtop Seals
- Welded Up Rust Holes
- OEM Door and Window Seals
- OEM Rear Door Lock
- New rear light covers
- New windshield with OEM seal
- Factory Tire Carrier
- OEM Mirrors
- Side Fender Badges
- Bezel Emblem
- Kaymar Hi-Lift Mount
- Bikini Top (track installed with nutcerts)
Drivetrain/Engine:
- Cleaned up POs de-smog job
- Air cleaner to valve cover hose
- 33x105r15 BFG ATs
- Factory Steel Wheels
- Gas tank hoses replaced
- Line in and return line
- 4" skyjacker lift
- Greaseable spring hanger pins
- Greaseable anti-inversion shackles
- Knuckle rebuild with koyo bearings and Marlin Seals
- New tie rod ends
- 4* Shims and new U-Bolts
- Air cleaner intake hose
Interior:
- Refinish dash knobs
- Bed liner
- Gas filler cover
- Front seats
- Year correct jump seats
- CCOT Jump Seat Straps
- Con-Ferr toolbox
- Heater rebuild
- Door panels with weather liner
- Door bushings
- Seat bracket lengthening
- Metal-Tech Jackson roll cage
- Tuffy console
- 5lb fire extinguisher
Electrical
[/QUOTE
- New headlights
- LED lights inside the cab
- Replaced light switch
- SunPro tachometer
- EL wire mod
- JVC Stereo (in Tuffy Console)
- Pioneer TW150 speaker boxes
- Interstate group 34 battery
No doubt in my mind, that rig looks like it belongs on that wooded road. And a top favorite color for this kid.
Best of luck!
Did you ever drill anything to mount the foot of your hi-lift? Still like the kaymar mount? I've seen them run on the driver's side but facing backwards to clear the door better.
I installed a Metal-Tech Jackson roll cage to make my resto-mod a bit safer. There are not a lot of photos of them from different angles, so I decided to add a few in case someone else was looking. I opted to have the cross dash bar not added.
Note, when ordering one make sure you ask about the seatbelt mounts. They do not list them on their website as optional (and an additional cost) yet show them in all their photos. Mine shipped without them and I had to order a pair. I don't have the ability to weld right now, so I ordered a pre-built model and not having the belt mounts was a long set back. Luckily for me there was an awesome guy in my club who was kind enough to weld them in for me. He is also working on a start up for some awesome looking ExPo trailers. They weigh around 800lbs empty and I rolled it around in the driveway myself, they are balanced really well. Maybe someday the 40 will tow one.
Were you able to mount the rear jump seats with the jackson cage without any issues or modifications?
I lined up the cage and made sure it was square (turns out it was a tiny bit off up from and cannot crank the DS window down without having to open the door, oops) and used the bolt holes from below the tub as a guide to drill up into the plates. That was the most challenging part of the rear cage. Its a solid plate, and you drill as needed. Other than that no major issues.
So you can mount the jump seats no problem? I thought I read on here that it took some sort of modifications to either that cage or the jump seat mounts to run them together. Maybe I am thinking of a different cage.
