IPhone App
Cooktown, Queensland
For those of you who have older vehicles (which should be all of us) and those who are running larger tyres on your rigs I found a free IPhone App called SPEEDOMETER. This app gives you your current speed while driving, altitude, allows you to set speed limits and has mapping and waypoints in it. Now I used this app tonight in my work vehicle which is fitted with a fully certified and calibrated Ballinger Speedometer and this app was exact with the Ballingers speed. So if you want to check to see if your speedo is accurate then I recommend downloading this app.
This is the one that I used.
cool, I've been using a free one of a different variety for my BJ74 which only has KPH speedo…
Downloaded this app and tried it out found it really easy to use worked really well and gives you easy access to your music thanks for the heads up.
I finally got around to getting this. The speedo seems to be calibrated well but I've now learned that it works when not in city traffic. Sometimes I can't get the map to come up on the iPad and it never does on the iPhone. i need to play with it more because I'm not sure that the problem doesn't lie with me.
