SOLD Iowa 1998 Toyota Land Cruiser 100 series w/ upgrades
Year
1998
  1. 100 Series
Iowa United States
Mileage
272000
Color
white
Hi All
Up for sale is a white 1998 Toyota Land cruise with 272xxx miles on the clock. This vehicle is in great condition and lived almost all of its live in California and is in great condition. This vehicle is equipped with fully functional rear and center differential lockers. Everything works as it should. AC blows cold heat is hot etc. this vehicle has a clean Iowa title in hand along with extensive vehicle service records.
While this vehicle is in great condition over all there are a few dings on the body just rear of the passengers side rear door. Essentially all the preventive maintenance has been done and is listed below with all of the upgrades that this truck has.
Mechanical: last 2 years:
-New alternator
-New rear rotors and brake pads (this year)
-New steering rack
-New lower ball joints
-New valve cover gaskets
-New throttle body gasket
-New plenum gasket
-New spark plugs
-New Upper control arms installed (Nitro gear UCAs)
-Slee differential drop kit
-Extended rear sway bar links
-Extended differential breather installed bring the lines to the engine compartment
-New swayaway off road torsion bars
-New thermostat
-New fan clutch
-New pulleys
-New AGM battery
-Coolant flush (replaced with Toyota OEM coolant)
-Constant oil changes with Mobil 1 synthetic oil and Toyota filters
-Differential oils all replaced
-295/75r16 BFG TKO A/T tires all around with a ton of tread left
-shocks and rear coil springs also replaced with Ironman off-road foam-cell equipment
Exterior and accessories:
-Land shark Drawer system installed
-Dissent off road front bumper
-Ridged LED pod lights installed in bumper
-10k synthetic Smittybuilt H2O winch (installed this year brand new)
-White knuckle off road rock sliders
-Ultraguage installed
Looking for $13,500.
Seems reasonably priced considering all the bolt on bits and maintenance. If you were closer to Georgia I'd be all over this. I'm in the market in this price range.
