- Joined
- Sep 16, 2008
- Threads
- 96
- Messages
- 2,930
- Location
- Freensville
- Website
- www.poolpartydeathmachine.com
- Thread starter
- #21
of course, leave it to me to do things out of order...
I decided to remove the passenger seat first to see if I should invest in anything to increase the height of the new seats, or if they'd sit high enough. The first three bolts came off easily, but the last one, well the track was frozen over it on the rail, and the spot-welds on the nutserts had broken, too.
why doesn't anything go smoothly?
Anyway, the easiest solution was to crawl under the truck, and drill out the nutsert with a battery-drill and a cobalt drill bit. That did the trick. I have a blurry picture of that to show.
Finally got the seat out, and lo-and-behold, a giant mouse nest, and a ton of old coins! Now I'm glad I removed the seat, bleeding vermin!
Next came the brackets, which I simply drilled out the rivets and spot-welds, and knocked them off with a BFH. Now for the moment of truth. I held uo a bracket to one of the rails, and... it fit perfectly over universal bolt-holes in the rails!
I finished collecting all eight brackets when I realized I had another problem, the PO brackets were raised in the rear, while the stock ones were flat, that's when I decided to use the raised ones on the driver's side, so I sit a little higher, and use the stock ones for the passenger. More time with the drill.
, and I have to wait for AAA to come.
and I really don't need or want anyone else to go with us. It's more than enough for us (no kids for us, either), and frankly I'd rather not haul around that little bit of extra metal for something that we wouldn't really derive much utility from anyway.
