Intermittent chirping noise from automattic transmission
Central Florida
Im getting a chirping noise coming from around the transmission area.
It only happens when in drive or reverse, not park or neutral. Also happens both when sitting still and moving. Any thoughts?
Thanks
It's pretty easy to see if the heat shields are use. They are above the cats and the muffler. Two of mine have come loose and rattled, although I haven't had a squeak. It's an easy fix by putting a fender washer underneath the heat shield bolt (as the shield rusts out right around the bolt).
