- Location
- United States
Hey guys,
I have a 6 tube LED kit that I used for footwell and trunk lighting in my 80. They have never been used outside the truck, but they were advertised as being outside compatible, so I'm pretty sure it'd be fine. They worked great and was very bright. I have since sold the 80. This kit was first installed by a local radio installer, who was rather incompetatant. I ended up cleaning up all his shotty wiring and getting it installed well. The wires attached to the main box have been cleaned up and reattached, but there are joints where I had to solder the wires, or use crimp connectors. There is a great fuse tap in connector attached to the positive end, and you can just attach the negative to any ground. These are super easy to mount. I just used small zip ties and they were solid for many months, and caused no permanent damage to anything. They are activated either by the main box, or by a remote, if you want a stealthier installation. The remote has a little wear on the paint, but it works great and I just put a new battery into it.
I used this kit mostly on the solid white setting, because it was a great, clean look in the interior, but it can do something like 25 colors (including a green that matches the interior lighting pretty well), and can go in 8 different patterns, come with sound activation, and at 5 different speeds/sensitivities.
Here are some pics.
Asking 75 shipped anywhere in USA
Here are some pics.
