Intake Manifold Removal?
New Mexico
Hey y'all I currently have a chewed wire for the front fuel injector in the even bank of the 1 GR-FE. Is there a write up on how to remove the intake manifold or ideas to repair without removal?
Wrong forum.
Aside from a Google search, I don't recall anything being posted, but don't take my word for it.
Also, you can load the FSM manual here at the second post: GX 460 Manuals
Downloading that will show an exploded view of all the components involved, which should be a great help.
Thanks for the link to that, I was able to find a manual on how to replace fuel injectors on a FJ that should work. I'm assuming the "Air Surge Tank" gasket should be replaced and not reused?
  • Like
Reactions: r2m
Quick update, I had to replace the fuel injector connector and used solder splices to connect it. Unfortunately I am still having a misfire on cylinder 2 which is what I began with. Thinking it might be time to throw in the towel.
The 2010 and up FJ Cruiser has the same dual vvti gr-fe motor as your 5th gen 4runner. Chances are a FJ owner or two have had theirs apart before. That’s why I suggested checking their site.
