Splain how you ran the RCAs off the amp, I am considering one of the double din units off of ebay and that sounds like the best way to install it.
This part is simple, just get a set of RCA cables, or buy a set of RCA plugs, and solder your amp wires to the center wire of the RCA cable, or the center post of the RCA plug.
2x
Simply adding RCA's to the amp shouldn't make an electrical difference unless Toyota is doing something pre-amp between the oem head unit and oem amp.
It makes an enormous difference. The factory radios have no built in internal amplification. They are essential just producing a source sound. Like a pre amp for guitars or home audio systems. What most on here try to do is take the easy route and just solder the amplified leads from an aftermarket unit directly to the factory amp. You don't amplify and amp. Those damn things are fairly noisy, even high quality ones. Those little mosfets, capacitors, and torrodial transformers make a pretty nice buzz. When you amplify a source that is designed to power a speaker there is going to be a ton of interference. Every time you amplify something you introduce noise.
Just look at the amperage draw difference alone. A pre out is only sending 6 volts at the high end, with very limited amperage. That amplified section is sending a couple of hundred watts and drawing 15 amps or so. If you ever walk by a large transformer you can hear the sound electricity makes, albeit is it less so with DC.
To save yourself from having to run 15 feet of cable, you can disconnect the wires to the factory amp, splice into the cables running to the factory amp, disconnect the wires from the factory amp output, and hook connect them to the spliced wires from the input side. You will get the same answer either way. Would still be much quicker just to solder RCA's onto the factory amp wires that are already behind the head unit.
