I'm installing a new double din JVC head unit with nav, dvd, bluetooth, etc.
I have it all wired up, but it's acting flaky. The big problem is that there is an awful hiss through the speakers. I'm using the factory amp and the hiss starts as soon as the amp gets power from the head unit, even if the volume is all the way down. In fact, it's there even if the speaker wires aren't connected at the rear of the head unit.
I've plugged in the old, stock head unit and the hiss goes away. I've also tried grounding to the chassis, negative terminal, etc. and the hiss gets better, but doesn't go away. When the engine is running, the hiss follows the revs.
What's going on? Should I try to bypass the stock amp?
