Installation of Thermostat Housing Sensors
88Retired62
TLCA #8993
Dallas (“M” Streets), Texas
May need to replace my original upper and lower thermostat housing electrical sensors in the near future. Feel free to correct me, but I thought I remembered, in an ancient MUD post, that applying liquid thread sealer to the sender threads prevents the proper grounding of the sending unit itself.
1. Ok, we all know…probably from a limited experience of automobile electrics, that cast aluminum
(Ie. thermostat housing) is acceptable but microscopically less acceptable as a grounding medium.
2. We’re all aware of “electrical” liquid and tape sealing thread products out there that I believe are intended to promote an electrical as well as a fluid connection/seal.
So give me some real hands-on experience and counter intuitive thoughts.
What’s the go-to installation approach?
I always use a thread sealant that says, Sensor Safe, like permatex high temp, and never an issue.
I try to buy the smallest size available, cuz this stuff doesn't last long once
opened
Sooo... This is such a great question 88Retired62 as I am about to do the same, replace all the sensors on the upper and lower thermostat housings.
I may be mistaken, but I thought one or maybe several sensors were installed with a copper washer between the sensor and housing??? The conductivity would be the housing of the sensor, copper washer and then the thermostat housing???
Thank you!
You’re absolutely correct,W.
Just didn’t want to “goop-up” the installation with an incompatible thread sealant. Might be likened to perfection personified but doing it right the first time is always the best path of least & lasting resistance.
Thanks for looking out for me! Heaven knows I need all the help I can get!
