Quixote said:
Awrighty, I will line up a shop to do the spring compression and coilover assembly for me. It may be difficult to find someone open this Labor Day weekend, which is when I plan on doing this.
Good plan, you won't regret it. When you go, pay attention to the relationship of the bolt pattern on top and how the bottom bolt goes in. Ours was put together, but needed to be tweaked a good bit. There are 3 bolts at the top of the assembly and you have to make sure that when the bolts are in the bottom of the assembly fits in the slot. I hope that made sense...
Quixote said:
A couple of other questions, if I may:
1) Looks like disconnecting the tie rod seems like a pain. The forum write-up mentions this but does not state what they did to address the issue. The manual says to us a "SST". Is there some kind of joint puller that can help?
2) The manual also says to disconnect the rear brake lines and bleed them upon reinstallation. I don't see anyone else doing this step - are the lines long enough when the rear axle is at full droop? Should I put a jack under it to be safe?
1) It was such a pain that we didn't do it, and oh how I wish we would have. Well, we tried, and that's when all hell broke loose and things went wrong. We tried to use a fork to pop it off, and that succeeded in shredding the seal and resulted in an order to CruiserDan (one tie rod end, please). Of course, that was after we tried to get the old parts out and they slipped and cut the CV boot (one CV book kit please). Do get the tool to get the tie rod end off and drop that thing.
Also, remove the sway bar links and get it way out of your way. With no room to get the assembly in, the sway bar links were in the way and that ended up in an additional order to CruiserDan (one sway bar link, please. Ummm, make that 2).
Those 2 steps will make your life so much easier. Without the tie rod down, the assembly was next to impossible to shove up in the mount.
2) We didn't touch the break lines, just did exactly what you are considering and put a jack under it.
I can see the more accomplished mechanics on here laughing at me on this one, all I can say is at least we tried and we were willing to screw up in order to learn. Before this I had no idea what any of this stuff did, and now I do and can fix it.
