Install Write Up: Kicker 46HS10 Subwoofer install in a 2005 GX470 Mark Levinson
San Diego
I just added a 10” powered Kicker Subwoofer to my 2005 GX470 and it was extremely easy to do. Can’t believe I didn’t do it earlier. I always thought the ML system was too hard to make any modifications or add a sub, but turns out it is very simple. Highly recommended for anyone looking for more bass with minimal modifications. I did some tests and the factory system really loses output starting around 70hz. I tested the Kicker and got solid output all the way down to around 38hz which is great for the size. The output between 40-70hz is honestly surprisingly good and adds so much to the factory system. It obviously doesn’t hit like two 12”s in a ported box with a proper 1000watt amp, but for the size/real estate it takes up, and ease of install, I’d say it’s worth it and really balances out the factory ML system.
I didn’t want to mess around with adding an aftermarket subwoofer to the factory location. It looked messy and every write up I saw, seems like it wasn’t really worth the effort and there was minimal bass gains. With the Kicker 46HS10 the low end is greatly improved. While the ML system is pretty good, the low freqs always left a bit to be desired and now with the Kicker I can actually feel the bass and when kick drums play. It fits fairly well underneath the drivers seat, and since the ML amp is already under the seat it made the wiring very easy.
Wiring Details:
Positive: For the main power wire, just cut the nipple off the driver side rubber boot and run a coat hangar with the power wire attached through it. It’s easily accessible from the interior.
Negative: I grounded it to the factory bolt that’s holding the ML amp in place.
Subwoofer Input: For the input into the sub all you need to do is tap into the rear speakers coming out of the ML amp. I highly recommend using Posi-Taps. They make it extremely easy and all you have to do is screw the thing onto the wire you want to tap and it automatically pierces it in the center. No cutting needed. Here are the wires to tap. The Kicker has a hi/low option built in so NO converter is necessary.
Remote Turn On: There is a DC offset option on the amp which in theory should turn the amp on via the speaker wires, however I don’t think there is DC offset in a 2005 GX470. I tried it and it didn’t work. No problem, just tap into the ACC power to the ML amp. It is the gray wire on the right harness. Again, I used a Posi-Tap.
Thats pretty much all the wiring, except for the bass control knob which is super simple. I ran it next to the power wire and then up and underneath the steering wheel.
All in all, I’d highly recommend this subwoofer for someone who wants more bass but doesn’t want to mess with the factory sub and is looking for an easy solution. Can’t believe I didn’t do this sooner!
Here’s some photos of the Kicker 46HS10 mounted under the drivers seat. First photo is with the seat all the forward during install, second is with it all the way back and how I drive. It’s a pretty good fit. Sticks out slightly farther than I’d like, but it’s not too bad. I do drive with my seat all the way back however. If you drive with your seat forward or have a lot of back seat passengers you could consider mounting it elsewhere.
So it fits that well with the ML amp also present?
Yeah, those photos above are with the ML amp in front of it. It sticks out a bit but not too bad if you drive with your seat all the way back like I do. You could of course mount it elsewhere but for sake of easy wiring to the amp that’s where I chose.
@psilocyBen
Nice write-up! Brief and to the point. Exactly what is needed and great pics. Bravo
Did you happen disconnect the factory sub?
Rich
What is your radio set up? I am currently using a cassette to aux adapter and want to upgrade to something better. I’ve seen those large screens for $800 but I am just not interested in those. Do you have recommendations to get music from my phone to the speakers?
I use this (purchased November, 2022).
Pros - price, dead-simple plug in to the AUX jack (not a GROM installation behind the dash), sound quality is great, battery life reasonably good although I keep it plugged in now, small and out of the way, connects very quickly once turned on.
Con - you have to physically turn it on every time (small button you see in the picture of the link above).
Good luck....and welcome to Mud! :)
Get the BT45-Toy. Bluetooth and an 1/8” aux input that wires directly to the factory stereo. The Bluetooth works great, connects instantly and I never have any issues.
Wiring Details:
Positive: For the main power wire, just cut the nipple off the driver side rubber boot and run a coat hangar with the power wire attached through it. It’s easily accessible from the interior. View attachment 2640349
View attachment 2640353View attachment 2640356Remote Turn On: There is a DC offset option on the amp which in theory should turn the amp on via the speaker wires, however I don’t think there is DC offset in a 2005 GX470. I tried it and it didn’t work. No problem, just tap into the ACC power to the ML amp. It is the gray wire on the right harness. Again, I used a Posi-Tap.View attachment 2640357
Great write-up! I followed all of these instructions however I used the JBL GT-PRO12 sub/amp combo with no luck. My amp won’t indicate any power or connection whatsoever. Indicator light is just completely out. I’m curious is my remote is not recognizing for some reason. I have a 2007 GX and my amp was different connections but I believe I connected to the correct ACC. I also had to use the high-level input on my amp for the input. However, this shouldn’t have anything to do with the amp not powering on.
