I just came back from mechanic for a safety inspection and they told me there was a little play (I did see it as they did it) in the front driver wheel and that inner tie rods need to be replaced soonish.
I am currently all stock suspension (no lift, still have airbags rear). If I was going to lay out a road map to slowly upgrade my suspension to eventually have a lift (2-3 inch lift, Bilsteins, nothing crazy) is there an upgraded inner tie rod that I should install now in advance since I have to do it? Or should I stick to OEM?
Also, is there anything else that I should replace together with the inner tie rod that would be a smart thing to do (preventative maintenance-wise)
Thanks for the advice everyone!
