can I replace injection pump for engine 1HD-FTE (electric type and full ECU controlled) with 1HD-FT (mechanical) or any mechanical injection pump compatible with 1HD-FTE.
I'll be great full for your advise and help
You can use an IP from and FT on an FTE but you’ll need to do other modifications before it’ll work properly. This is NOT plug and play.
There are a lot of folks who prefer the manual pump on an HDFTE (electric) which is then called an HDFTM (manual). Check out the HDFTE as well as the HDFTM conversions page on Facebook. Hope this helps.
