1
First you adjust the sensor to give the correct height on both sides.
2
Then you do the neutral-pressure test that you have seen in another thread, and crank up the T-bars to achieve the correct pressure. (That's what the pressure test is for...)
If that doesn't work out, I would say you have a problem in the rear. (Maybe inspect the coil springs before you start)
2
