OK, so just had motor rebuilt by reputable shop. 1984 FJ60, now .30 over, stock cam, new everything internally except crank was polished. Everything was installed by them except I installed the carb and connected up the remaining desmogged lines and the air box. Ran fine before, just had low comp in #3 and burned oil and gas like crazy. Had a hell of a time getting new motor started, finally moved the dizzy up two teeth to the right clockwise and it started, ran rough but got it up to 2500 for 20 min in order to do the break in. As soon as I dropped RPM below 2000 it want down to zero like a rock, had to pump pedal to get it going again. For now assuming new cam and crank are installed correctly, so chasing anything else before I tow back to my builder. I did put the dizzy back a tooth to where it should be per manual, as I want this right, not just barely running at 2500, but all correct. I found an issue with ohm check from FSM Fig 8-16 and 8-17. First primary side was 1.4 which is too high and the secondary doesn't give me anything at all. I switched coils but no diff. I do have spark through coil but thinking it is not enough and or out of sync. I swapped coil but same issue. My guess is the Igniter somehow got fried in the process but it did pass the two 12 volt checks in Fig 8-12 and 8-13. The dizzy is for sure at TDC and for sure it is on the power stroke and correct to how it should be with rotor pointing at correct angle to No 1 wire. So again, thinking Igniter, or maybe fusible link, or maybe the signal rotor in the dizzy. Any help would be appreciated before I point finger to building making rookie mistake of not getting timing gears installed correctly.
