From what I have learned about NC so far, it would pass using the GOB method. Go out to Sanford, talk to the troopers, go next door, reset the ECU - it won't throw the code for X miles . . .its all good in the 'hood!
What's the "GOB" method?
NC inspection, for all OBD2 vehicles right now, requires plugging the vehicle into the inspection computer. If there are too many "not ready" codes (aka you reset your computer) or if any codes are thrown, then you will not pass inspection.
This is true for most states. The only way you can get around that on an EFI vehicle is like a 88-95 land cruiser, where the state does not require plugging into the inspection computer. That means they just look at the CEL to make sure it comes on with the ignition, and turns off when running.
If the lottery comes knocking, my 2004 100 will be converted to 5 speed manual.
Love manuals.
Wouldn't be able to pass inspection in NC if you did :/
Didn't even think about this... how did you and Mike get around it in his 80?
Haven't. Put a venezuelan ECM in it from a factory 1fz/h151 and the CEL is off (as expected) but we can't inspect it. Unfortunate and unexpected consequence of the conversion.
A little birdie told me that 2020 is when 1997s won't need emissions inspections anymore, something about NC GOP changing legislation to not require it anymore.
Ah so trail rig only registration then?
This is why the 95 Cruiser is the best. All the benefits of OBDII but none of the hassle of emissions at inspection.95 and older the CEL just has to be in working order but it doesn't matter if it is on when running.
"Vehicles made from 1995 and older do not require a North Carolina State Emissions inspection. They are safety inspection only. The vehicles made from 1996 and newer require both the NC safety and emissions inspection. For the emissions inspection the check engine light must be in working order (illuminate when the car is first started) and be off otherwise. For the safety only inspections the check engine light must work but it does not have to be off to pass inspection."
