Icon Vector 5 (8 Viewers)
I am about to order these same wheels and 285/75/17 Toyo ATIIIs for my 2016 LC. I have about a 2.5 inch Dobinsons lift and Dobinsons UCAs. Aside from some trimming and heat gun for plastic, did you do any real mental cutting or KDSS relocation to make these fit without rubbing? Thanks
Just a heads up I ordered a set of Titanium this week from Discount Tire using a price match, they showed in stock online, but they turned out to be 6-8 weeks out as they have a shipment on the water. Other companies might have them in stock…
I ended up going with these a few weeks back on our 2016. Really happy with +25, and given the sale Icon was having I couldn't say no.
Really like this look. Purchasing a face lifted lx right now. What size tire and what finish are these wheels? Cannot tell if it’s the black or titanium?
Tire size 285/70/17 BFG KO2. Only modification I made was pinning back the mud flaps after attempting to mold them back with a heat gun failed and I didn’t want to trim them. No rubbing since. Color is titanium. Pick up a set of ET lugs for peace of mind.
Appreciate the heads up...not in too much of a rush but can't wait to fill the gaping wheel well left behind after my lift.
What are you guys doing about mounting the Vector 5's underneath the vehicle in the stock spare tire location? I tried mounting mine underneath however the wheel bore size is too small to slide the spare tire chain assembly through. So right now I have the stock 18" wheel in the spare location but in the even that I blow a tire I'd like to at least mount the Icon's in the stock spare location so I don't have to put it into the vehicle. I'm not running a rear swing out tire carrier so that is not an option.
What are you guys doing about mounting the Vector 5's underneath the vehicle in the stock spare tire location? I tried mounting mine underneath however the wheel bore size is too small to slide the spare tire chain assembly through. So right now I have the stock 18" wheel in the spare location. In the even that I blow a tire I'd like to at least mount the Icon's in the stock location so I don't have to put it into the vehicle. I'm not running a rear swing out tire carrier so that is not an option.
I think there is a difference on 2016+ for the spare tire carrier. I remember reading about similar issues for the Rock Warriors. Anyways, mounting my spare just worked on my truck without any mods or effort.
Get a pipe cutter and cut the metal cylinder above the t bracket shorter. No need to remove the cut piece off the chain, but you can if you have a grinder.
Agreed. The vector 5 fits perfect underneath my 2018. Although it is on its way out shortly.
You have to cut and modify the chain assembly, that’s what I did at least.no need to remove it just grab an angle grinder and some touch up paint. One of the ears need to be cut back.
Are you getting rid of your Vector 5's? If so...why aren't you happy with them?
One thing that really falls short with these wheels is the valve stem location.
I have ripped mine out or damaged it on three different occasions.
Any update on your ETA? Ordered mine (bronze) at the same time directly from Icon. Just spoke with them on Friday and they said they’re looking like second week of March before they ship. I have resisted buying something else in the interim because I know I’d regret it. They really are the best looking wheels I’ve seen on an LX/LC.
Im very stupid but how is it possible any 110mm bore wheel wont pass through the factory lug lift bracket?
I did not know this was an issue... Is it just the outer contour and deep offset?
